1 - 4 of 4 Posts
Just ordered the Termignoni exhaust. I have read there is a key that is remaps the bike has any 1 done this. Do I have bring it to a dealer to have them do this or can I do it my self with what comes with the exhaust system
Yes you need the dealer to install ithe map (at least I did, it may be possible but I didn't know how). I had my Termi before I even had my bike, which I picked up by trailer, so I had it installed (flashed) before I left. I installed the termi at home as soon as it was off the trailer, so I never had to run one without the other. (It also runs "much better" with the DB killer removed )
Is there a key like I have read that is used when you take out the baffle removed
I believe the slip on has the same vertical pin in the dbkiller that is designed for pliers or a hook to aid in removing as my full system does. It tends to make a whistling veedub sound and I removed it...never put the dbkiller back in but fairly sure you'd still get it out if needed.
1 - 4 of 4 Posts
