From what I've read, the o2 sensors are only used by the ecu at very low rpm and when the rpm is held at a constant for long periods.
I thought the throttle was the cause of the snatchiness at low constant rpm but it seems due to emission regulations, the o2 sensors actually cause poor fuelling.
If the Termi race map doesn't turn off the o2 sensors, I'm wondering if using an o2 sensor elimination kit will help.
I'm not looking to use anything like rexxer.
