Apparently. The LCD is larger(4.3”) a different shape and in colour. The quick shifter is an option on the Icon and standard on some other models.Is it true that the 2023 Scrambler Icon base model that comes to the USA in Spring will come with the upgraded LCD screen and can also be upgraded with the quick-shift?
Your description is in line with what I thought I had read or heard. I knew the Nightshift came standard with the new LCD and quick shift, but I wasn't sure about the 2023 Scrambler Icon. Thanks for your reply!Apparently. The LCD is larger(4.3”) a different shape and in colour. The quick shifter is an option on the Icon and standard on some other models.
I may have misunderstood, but I believe that the gears can be shifted without using the clutch if it has a quick-shift.Hmmm…I’m getting conflicting info on what a quick shifter is. Is it like an auto shifter where you don’t have to use the clutch up and down, or does it simply make the clutch/gear change faster/better?
Most new spec quickshifers allow up and down shifts without the clutch being used. You only need the clutch to start and stop.Hmmm…I’m getting conflicting info on what a quick shifter is. Is it like an auto shifter where you don’t have to use the clutch up and down, or does it simply make the clutch/gear change faster/better?
THANK YOU for clarifying that.Most new spec quickshifers allow up and down shifts without the clutch being used. You only need the clutch to start and stop.
having clutchless shifter requires that the bike has ride by wire throttle, and together with sensors it instantaneously blips the throttle... for the first time the 2023 scrambler 803 comes with ride by wire throttle which makes it possible to have a quick shifter - I have a 2022 icon, so no quick shifter but I have it on a triumph street triple and had it on bmw f900r - and on those bikes it works very wellWhat, even downshifts?
How does it blip throttle to match revs or does it just mash it?
I get it for flat out upshifting but using no clutch ever, well I wouldn't want to be the second owner. Never saw the sense in them off racetrack.
Sent from my SM-G996B using Tapatalk
They have become almost standard on mid to high end bikes over the last couple of years and going back to your never buy a s/hand one comment I think you 100% wrong. A bike with a down quickshifter is far less likely to have clutch or gearbox problems than one that has a standard clutch that has been used incorrectly.Ah I see. My Audi did that (but it still had clutches and the ECU controlled those too)....Didn't realise it had trickled into bikes...especially retro ones.
I'm still getting over fuel injection on motorcycles.
