Hi All,
I bought the RexXer Evo unit last year and installed a new map on my bike.
I only had the chance to ride the bike for two very short journeys last year due to the poor weather as it was Autumn going into Winter.
Having now had the chance to ride it lots, I've had the notorious airbox backfire and no power (almost stalling) when I've blipped the throttle on a downshift.
Prior to the RexXer map, this would happen a fair bit but I'm wondering why it is still happening with the RexXer map installed as according to what I've read, the airbox backfire and stall/no power is caused by lean/poor fuelling and the Secondary Air Intake system.... both of which the RexXer map should of dealt with (I've had the o2 sensors disabled and physically removed which apparently should disable the Secondary Air Intake).
I've messaged RexXer to see if the Secondary Air Intake has been disabled either through the ecu or through the o2 sensors removal.
Is anyone else with a RexXer map installed also getting the airbox backfire etc?
Many thanks,
Duncan.
Many thanks,
Duncan.
