hi all , found the free play movement in my twist throttle was quite a lot , adjusted it to a very small amount , you must make sure that the adjustment you have made is the same with the bars turned in all positions lock to lock , I have found by doing this that throttle controll is vastly improved , hope this might help others , adjustment is the knurled nuts near the throttle grip .
