I've heard the new Multistrada is even smoother low down with the VVT.Never tried a Diavel. Only Ducati sportsbikes and streetfighter
Canister delete did not do the trick for me, neither did the Termi pipe and remap. Horrible throttle.I love how when people report that the throttle is way too touchy others chime in and say "it's fine for me, or even better... "infer that others just don't have a smooth throttle hand".
I have been riding motorcycles for about 32 years. Can't remember if I was 10 or 11 when I got my first kx80. I was a pretty successful racer when I was younger and also enjoy trials riding now. Trials riding takes way more throttle control than riding a street bike ever will.
Belive me when I say, some of the scramblegs have an aweful throttle. Mine is ok I suppose but definitely NOT what I expected from a Ducati. I stopped by the dealer the other day and was asked..how d you like your scrambler? I said it's great except for the ridiculous throttle response curved. He immediately said "oh yeah, the trigger throttle, we are working on that".
For what it's worth, he did say that deleting the California emissions canister would help a little bit so I'm going to try that thus weekend.
Maybe I will look into a throttle tamer. Applying a surgically small amount of throttle and having the bike jerk forward on a nice smooth turn is really a drag.
You have to remove the left and right airbox covers, then the main airbox cover that houses the air filter.I've got the same tamer and the same problem without enough cable adjustment. How much do you have to take the bike apart to get to the throttle body? Is it then easily adjusted once you get to it?
I'm sure the adaptors will be the same as yours as they are about the shortest you can get.What adaptors do you have on the abba stand?
They seem longer than mine - just thinking about making longer ones
But looking at stand it looks like it is not wide enough to fit longer adaptors to clear the pegs
I have the Monster ones on mine but they need to be 35mm longer a side to clear the foot pegs - so 70mm and the frame has only 40mm more before the arm is over the end.
Can we get more info and photos?
THANKS
Thanks again Shamone, to get to the airbox cover do I need to remove the fuel tank?You have to remove the left and right airbox covers, then the main airbox cover that houses the air filter.
No it's all done front the front of the bikeThanks again Shamone, to get to the airbox cover do I need to remove the fuel tank?
It would be great so to be able to purchase also the genuine ducati heated grips with this progressive tube because at the moment a limitation of their heated grips is that they come with a throttle tube glued to the grip, this means that for someone like me that has a throttle tamer installed and doesn't want to uninstall it, I cannot basically have their heated grips installed, as this would mean I have to uninstall the throttle tamer I have installed.I just read on an Austrian website how Ducati tamed the jerky throttle on the Desert Sled: progressive throttle tube instead of a linear one.
So basically, they installed a tube similarly shaped as the G2 from the factory. Which is good I think because this tube may resolve the cable play issue.
The heating element is on the throttle tube not the grip, so at this point it would be simply great if we could order that heated grips from the desert model so that we have heated grips with more gentle throttle.Could you not break the glue from the heated grips and the factory tube the same way you'd break the glue between any other grip and tube?
