81 - 92 of 92 Posts
Sarah, I wasn't there so I don't know the details except the replacement part is around 6 bucks. I've never looked under the tank and now I'm kind of afraid to! The parts come in Tuesday and I should be able to pick it up Tuesday or Wednesday. I'll talk to Michael the shop manager about what broke and how they deal with sticky fittings and if there are any special tools they use.
From the manual: looks like there is only one fuel connection? #14 would be the only thing that could be as cheap as 6 bucks....
Product Water Auto part
Yep, I'd say you're right. Thanks, hope you'll have your bike back straight away.
What I know from my shop: they remove the hose from the fitting, not the fitting from the fuel pump. They did replace some parts while doing the valve check. So, something broke, but I'm not sure what. Anyway, I've payed this year's Desmo Angels' share and am now ready for some riding.
They may have learned the hard way, too. I have a fuel pump on order. Quite a punch in the gut.
Greetings all, I'm awaiting the arrival of a Rapid Bike Evo module for my Scrambler. I've read this entire post and the workshop manual and I'm wondering if simply placing some blocks of wood under the tank would give me enough clearance to route all the RB cables etc...I will have a friend helping me, so he could hold the tank while I disconnect the fuel lines but if I can avoid messing with them I'd prefer it.
Also, my understanding is that the two fuel lines, (black, grey), should be connected back the same way? The vent hoses, which I'm not sure where they are...are there two of these? Does it matter which goes back where?
I also think I understand how to remove the fuel lines. Middle and Thumb, press/push flange A into the fuel pump, while index finger gently pushes the hose in the same direction until I hear something un-click. When this happens, keep holding the flange A and pull the hose out.
At this point, should I expect some fuel to be coming out of the tank or are there valves which close once there are no hoses inserted?
This is what the RB installation manual says and it contradicts what some of you have said with regards to disconnecting the fuel pump connector.
Before disconnecting fuel hoses, relieve pressure from the system as follows:
1. Lift and support fuel tank.
2. Disconnect fuel pump connector.
3. Start engine and let it idle until engine stalls.
Thanks.
I think you'll have room to route cables once you've lifted the tank a bit.
Updating the thread since I went through the pain last night! Few hours and I could not get the sucker out!
What made a huge help was the following:
While standing on the right side of the bike I lifted the rear of the tank with my left hand. I reached with my right hand between the handlebars, under the tanks and that way I was able to use my nails and fingers to remove the breathing lines. After that I was able to put the tank on it's side to get "unlimited" access to the fuel pump connectors and really push in the elbows while holding the plastic nut, they popped out easily
44257
Glad you got it done and everything is ok. Were you doing the tank removal to route cables? I'm only asking because if it's for cable routing, it's not necessary to remove the tank, providing you don't care that the cables will not be under the tank.
My whole front is shuttered - see my other post for the ignition lock. I need to inspect the damage on the tank itself, remove the instrument cluster with all its cables in order to send it to be reprogrammed as well as replace the clutch and brake lines as they are broken and without fluids
Hi all, I wasn‘t able to disconnect the fuel lines, so I ended up cutting them and put in some quick connectors. They are small enough to fit in that little space under the tank.
So today I took the tank, the side panels and the mudguard to the paint shop.
Tire Photograph Wheel White Light
Light Product Camera accessory Font Cameras & optics
2 months later and I have to tell you that these small quick connectors DO NOT FIT under the tank. First I just couldn‘t believe it and tried to squeeze the connected fuel lines in, but the one on the left side really didn‘t fit in no matter what I tried. 😖
In the end I had to take the bike to the dealer where it got new original fuel lines 💸
81 - 92 of 92 Posts
