Cheers David, but forgot to mention I've got r&g frame sliders on so might be slightly different but I think the vibes I've been feeling are that my bolts have been re-torqued by the Ducati mechanic to about 10nm!! I could spin the slider with my hand wtf! Just checked the service sheet and it says they checked it or should I say slackened it.Service manual says 60 Nm. I re-torqued them recently while making a maintenance service and they didn't snap :biggrin:
Even if you have the R&G frame sliders, torque value shouldn't change, unless you changed bolts. What matters in a bolt connection is a pretension in bolt, which is being achieved while tightening. The pretension should be equal to around 90% of an yield strength of a bolt, otherwise it will simply get loose. You have to imagine that a bolt actually works like a spring - if the proper level of a pretension is not achieved, spring force is too low and bolts start to loose (this is a very simplified explanation). That is why using torque wrenches is very important, especially in places where everything constantly vibrates and constantly expands/ shrinks due to temperature changes.Cheers David, but forgot to mention I've got r&g frame sliders on so might be slightly different
That is why I always do a maintenance on my own. Wherever I go, mechanics always do something wrong with my bikes... I lived in 4 different countries so far and everywhere is exactly that same - doesn't matter if it's Ducati or Harley.my bolts have been re-torqued by the Ducati mechanic to about 10nm!! I could spin the slider with my hand wtf! Just checked the service sheet and it says they checked it or should I say slackened it.
ONLY grease threads if the manual prescribes so. Else you're actually over torquing.Before re-torquing, make sure that the bolts threads are greased. Grease helps to decrease a friction coefficient between a female and a male thread - if the friction coefficient is too hight (not greased, dirty threads etc.), you will not achieve proper pretension, even thought your torque wrench will indicate that you did (think about rusted bolts and how hard it's to bolt them sometimes).
That's why I attached a snap from the service manual, as a confirmation of my wordsONLY grease threads if the manual prescribes so. Else you're actually over torquing.
On dry, clean threads about 40% or so of the applied torque is lost in friction. When you grease the threads this number lowers to around 15%...
Wouldn't agree here. Max Kool is more correct here:Torque settings are nearly always quoted ‘wet’
For cylinder heads and most internal parts of engines your statement is correct. But for body, chassis, brakes and everything else not really.ONLY grease threads if the manual prescribes so. Else you're actually over torquing.
LOLWouldn't agree here. Max Kool is more correct here:
Best example is lug bolts. Car manufactures give us a torque value but never say to lube bolts. And that's why greasing lug bolts with copper grease is a big mistake.
LOL Copper grease is not a lubricant but it decreases friction coefficient between materials. And this friction coefficient is the most important.LOL
For a start copper grease is not a lubricant, it’s an anti-seize.
LOL it is not. It is outside of it.I presume a frame bolt is not inside an engine ??
No, they are not wrong. You are, as you don't fully understand the topic.Maybe the whole oil & gas industry is wrong too. Maybe I’ll get my engineering colleagues to read and learn from this. LOL
I understand fully, despite your arrogant assumption about my knowledge on the topic. In fact I’ve probably forgotten more than most people have learnt. Strange how you say my collegues are correct but then you say I’m wrong when actually I say exactly the same as them.LOL Copper grease is not a lubricant but it decreases friction coefficient between materials. And this friction coefficient is most important.
I studied bolt connections for a while, as I am a mechanical engineer (working in nuclear research) and I calculate torque values quite often. You would be surprised how complex and advanced research has been done on it.
I am an active member on few forums and you are the first one I have ever been arguing with (unfortunately this is not the first time). You don't want to accept any other opinion than your own. For me you are very conceited. But this is only my opinion.I understand fully, despite your arrogant assumption about my knowledge on the topic. In fact I’ve probably forgotten more than most people have learnt. Strange how you say my collegues are correct but then you say I’m wrong when actually I say exactly the same as them.
It’s been verified that Ducati recommend lubricating the bolt/nut but then ‘you’ say not to as it would only be inside an engine that it applies to. WTF.
Anyway, I’ll carry on doing it my way and you keep doing whatever it is you think best.
This says it all. This is just physics. Knowing this (and accepting the above is true) automatically means you need to know if a torque value needs to be applied wet or dry. That's engineering 101. A typical mechanic's handbook specifies all bolts/nuts to be torqued dry, unless specified otherwise.On dry, clean threads about 40% or so of the applied torque is lost in friction. When you grease -or oil- the threads this number lowers to around 15%...
As you say, it is a part of the 7.5k service. Check the attachment - the snap comes from the owner's manual. And I am pretty sure that the mechanic will say he did it rightWhat if the mechanic says he never touched then engine bolt? Even though I'm sure it's part of the 7500 mile service (Ducati service guy said he's the top mechanic) I've now torqued it to 40nm (r&g setting).
