1 - 6 of 6 Posts
Hi everyone, I'm getting the new Ducati Scrambler HashTag. Apparently it's the same bike as the Sixty2, just different colour scheme. Anyone knows the torque specs for the oil drain nut and oil filter? Planning to DIY the oil change. And if anyone also knows where I can purchase the service manual online?
I am assuming that they will be the same as the standard 800cc Scrambler. The workshop manual for that is fairly easy to find on line in PDF form if you let your fingers do the Googling.
Careful with the drain plug as I believe the manual torque settings are on the high side and have been known to strip threads.
It's just a drain plug anyway. All it needs to do is plug the hole. (and they use a compound on the threads anyway)
1 - 6 of 6 Posts
