1 - 4 of 4 Posts
A question for all you semi-pro spanner weilders…
If I was to buy a torque wrench what operating range would you suggest?
I won't be doing engine strip-downs mostly easy DIY stuff.
TA!
You want at least three. Torque wrenches are best used in the upper half of the scale.
One for lower torqued bolts/nuts, like up to 30Nm, one up to roughly 80Nm, and one big one for the wheel nuts, that can at least handle 150Nm.
That sounds expensive! Cheers though Max. I shall have a more considered think about the type of jobs I will do. It only came to mind with a simple fitting of rear pick-up bobbins recently which requested I tighten them to 8Nm, currently I'm doing it by rack o' eye, twist o' gob.
that's exactly why. 8Nm is very little. It's like the force you can exert by holding a spanner between your thumb and index finger right at the head only, and resting you little pinky on the end.
A torque wrench that goes up to 80Nm cannot be used for those low values, the weight alone could strip the thread...
1 - 4 of 4 Posts
