1 - 3 of 3 Posts
I am pretty sure I am going to order a Tutoro oiler and want to make sure I order the right kit. I’m assuming to “Pro” kit is what everyone bought? Also, do you think I should get the HghTemp oil for Florida? (I am a fair weather rider )
Last question, any real downfalls or reasons not to put one on?
Thanks
I don't have any experience with chain oilers , but I ride in the woods of central florida pretty regularly and haven't have any issues with my chain needing to be oiled, or lubed, more often than any other bikes I ride with. Granted I wash my bike after really dusty, or muddy, rides and spray lube on the chain every few washes, but this might seem like overkill. On the plus side, it's one less maintenance task you'll have to worry about all the time. The check would have to be a lot less often than the method I use.
Hello
I've installed a Tutoro Oiler on my Scrambler and I'm really happy with it. I ride approx 3000 km with a filled tank, no need to have a largely opened flow. , Mine is quite entirely closed and it's really sufficient to have an always oiled chain even in bad weather conditions.
The hotter will be the weather, the thicker oïl you should use, this is the only rule.
1 - 3 of 3 Posts
