1 - 20 of 21 Posts
Not sure if it's just me but my bike seems to be vibrating more and more each ride, I can now feel vibes in the saddle and foot pegs but not any in the bars, is this normal? I remember the bike been mega smooth but I think it was with the slip on exhaust which I've now sold. The vibes start at around 4500 rpm up to around 6000 ish it's not mental vibes but defo noticeable, anybody else experience this sensation whilst riding?
My Yamaha FZ1 - used to be very sensitive to chain tightness - i used to have to run it tighter than normal to stop snap and vibration - my two Ducatis - dont seem to mind - so I run them a bit looser - but maybe you should check
When mine was delivered - mid way on bottom run I had 40mm slack from pushing up and pushing down with good finger force (this was measured on centre line of chain) so I have used this number and it works fine - worth checking.
If the vibes stop when you pull on the clutch, it may come from the chain. When you pull the clutch, the chain is no more in constraint, so...
Yes, also, check your tyre wear : you should find on the side of the tyre "TWI" written (Tyre Wear Indicator). At this place, the tyre has got a molding at the bottom of the tyre grooves. If this molding is at the same level than the surface of the tyre groove, your tyre is good for change.
Hmmm I was wondering the same recently, my bike felt more vibey in the pegs but it has two newish tyres so not that. It is however coming up to it's 7500 service, will be interesting to see if it's any better afterwards!
Please let me know if anything changes, the vibes are beginning to annoy and putting me off my ride. I do ride quite hard but not mental and do pull the odd amateur clutch wheelie but she is fully serviced and well cared for. I've checked all the usual suspects (engine mounts etc) but nothing was out of spec.
Will do, I hope to book it in for some time in June. I only tend get the vibes on the pegs at higher speeds on a straight run, I've not really noticed them at other times - but I'm sure they weren't that bad to start. Anyway will keep you posted.
Discussion Starter · #13 ·
I lifted my tank up and the tank breather must of been trapped as it let out a large hiss and a pipe full of water came out! The bike now runs back to normal??? Could a trapped breather cause vibration/rough running?
As the fuel pump tries to pump fuel to the injectors it will cause a vacuum in the tank if the breather is blocked.
That might cause a reduction in fuel pressure which in turn will affect the engine running, and probably it's smoothness. Sort of like a fuel blockage.
Reactions: Armo
Discussion Starter · #15 ·
Just been for a ride today and it's still there?? I noticed the vibes started when the clutch wasn't disengaging properly when I'd left the bike for a week, so my next question is could a clutch cause vibration at 4000+ rpm?
When riding at these revs if I touch the passenger side of the saddle it feels really vibey.:confused3:
If one of the friction materials has come unstuck from a plate, or broken, it would cause unbalance.
It would throw the whole clutch hub out of balance.
Hello! I bought at used desert sled a few weeks ago, the bike is gorgeous, but the vibrations are horrible, it starts at around 4000 rpm and goes all the way up to 6000 rpm which is so bad on highways that i cant hold on to the tank with my legs without them getting numb due to the vibrations. Ive tried just standing still and revving the bike up with the same result, so its not the tires or chain as suggested before.
It has been serviced as it should and has about 14000km on the clock.
Is this normal?
Is this normal?
Not normal. Mine has 7500 mi and no crazy vibration. However, when you say vibration, what are your reference points? This is an air cooled engine. It will sound like an older Porsche 911. Are you comparing this to an inline 4 water-cooled?
The sweet spot in this engine is 4-6k rpm.
Some things to consider: What year is the bike. Age of the chain? Chain alignment?
Thank you for your answer :) it's 2017 and I'm comparing it to my previous bike which was a MT07. The chain is soon due for a change, but the vibrations are still there if I just rev it standing still, it has the termigioni exhaust and mapping, could it be a contributing factor? (Think I also have the famous termigioni rattle...)
Have the yearly service booked in a few weeks with a replacement of the rear tire which start to look a bit flat, might aswell change the chain and sprockets aswell
Does anyone have experience with the MT07 and how its compared to the scrambler, vibration wise that is?
Mine is a 2018. I don't think the vibration is unusual for this type of engine configuration. I think you will find the parallel twin, cross plane, water cooled, to be smoother. I don't have an MT07 though and this is pure speculation on my part. The good news is you are already taking it in for the annual. Let them know about the vibe. They will tell your their thoughts (and if the Termignoni is a contributor. Also, go ride another scrambler with the same engine!
1 - 20 of 21 Posts
