1 - 14 of 14 Posts
Just about a block from home not fully warmed up and with a little less than 1/2 a tank full of gas going approx. 15-20 MPH turned onto a connecting street (left turn) at a pretty extreme lean (close to pegs hitting) and the motor cutoff like someone turned the key.
Kept running but was kind of a shock especially at the extreme leaning point I was. I wouldn't think I was leaned over far enough to activate any safety switch, but who knows. Never happened before so it was kind of an odd occurrence. Anyone else ever had that happen?
Just putting this out there, but is it possible that the side stand or spring is loose? I have caught a pant leg on the stand when putting my foot down and the safety switch killed the engine immediately. Maybe something is loose down there causing the gravity to pull on the stand enough to move the switch and kill it. I think I remember littleowl mentioned her stand almost fell off at one point. (Apologies if I have remembered incorrectly.)
Just putting this out there, but is it possible that the side stand or spring is loose? I have caught a pant leg on the stand when putting my foot down and the safety switched killed the engine immediately. Maybe something is loose down there causing the gravity to pull on the stand enough to move the switch and kill it. I think I remember littleowl mentioned her stand almost fell off at one point. (Apologies if I have remembered incorrectly.)
I'l check that out, that would make sense since it's the left side. Good tip! Thanks
I'm guessing the side stand switch was set off too.
Doesn't sound like you were downshifting or doing any abrupt fueling.
I've had my bike cut out on rapid downshifts and had it cough once or twice when trying to lug it through a turn at too low of RPMs. Doesn't sound related.
Yes you have remembered correctly, it was loose (friend noticed it as I would have been none the wiser!). A possible cause?
1 - 14 of 14 Posts
