1 - 11 of 11 Posts
  • Found these on the Touratech website, made for Ducati Brembo brakes.
    Are they worth it or is it just another part you don’t need?
  • Oh! And BTW they also do them in red.
They also help keep the heat in - that could be a bad think on heavy braking...
A piece or worthless bling is my opinion..
Talking of that... did you ever get the Ohlins finished?
Mate.
Do you think the same about the Evotech which I have?
Had a warped front disc changed (under warranty) that I put down to panic braking at Brands. Think the Evotech was already on.
Cheers
No - if anything these would help the cooling... they still allow the air through the caliper... but add additional surface area and a solid mechanical fixing to the caliper which should help conduct away heat...
But these are really meant to protect side caliper from impact rather than help cooling.
Which I guess it does if you ride off road... on road... not sure they would do too much.
Discussion Starter · #11 ·
Simon
Just this minute got back from Preston. Had my cartridges installed and handed my shock with its titanium linear spring. The guru said that the OEM shock has a progressive spring and it looks cheap and nasty but can be rebuilt.
Anyway my weekend has been taken care of now nailing the suspension back on.
1 - 11 of 11 Posts
