Hi sorry to resurrect an old post, am thinking of changing all of my bearings. Some weird sounds rotating the rear wheel and the front dues grab a bit on my 2015 3.8k icon.
Are they just straight forward for both wheels all 6 of them?
I don't have any special tools just planning to tap then out and get the new ones from the freezer in.
Any advice welcome. Cheers
Hi, I changed my rear wheel bearings 3 times and feel like I’ve become a pro at doing it now.
The sound your bearing makes when going bad is a really bad clunking/binding sound, if it’s gone bad and you waited too long it could destroy your axIe, wheel hub, and swingarm. If you don’t feel confident take it to a dealer or indie shop.
I bought this tool to remove them,
Pit Posse Wheel Bearing Remover
It seems unavailable now but motion pro makes an equivalent.
I cross checked a lot of Ducati OEM wheel bearing part numbers and read somewhere that depending on luck you may get OEM bearings from China.
I found the equivalent bearing on eBay, made in Japan. I’ve done multiple track days on these bearings riding the absolute piss out of my bike and no issues so far, my bearings going bad previously we due to spacer issues from swapping my wheels.
I did not change the sprocket carrier bearings, they are much bigger than the front and rear wheel bearings and costly, from my part checking I figured out it’s cheaper to buy a used sprocket carrier from eBay than to purchase and replace the bearings in your hub.
Find many great new & used options and get the best deals for KOYO 6005 2RS C3 Deep Groove Ball Bearings 25x47x12mm SAME DAY SHIPPING! 6005RS at the best online prices at eBay! Free shipping for many products!
www.ebay.com
there’s a bunch of guides on YouTube, but basically you need some grease, a mallet, and a socket that matches the external diameter of the bearing. You could also buy a tool specifically for this but they serve the same purpose. Tap the bearing in around the edges in a circle until it’s half way in the hub and even on all sides, then use the socket/bearing tool to whack it in, but be careful to not hammer your hub or the inside of the bearing, It’s very easy to damage it!
Don’t do what I did and install both bearings without the axel spacer in the middle
