1 - 8 of 8 Posts
So I wanted to upgrade the H4 OEM head light bulb to a Philips Racing Vision. So I am perplexed on how a H4 bulb can be different. A picture is worth a thousand words. The base of the Philips bulb is a bit taller as compared to the OEM. The glass part of the bulbs are the near the same length. On the left is the OEM bulb and the Philips Racing Vision is on the right.
End result the access cover of the head light will not fit flush.
The base of nearly any H4 is longer than the ones fitted to the Scrambler is my experience so far. I found finding a replacement very hard.
Still confusing. When you google you find H4 are primarily used in motorcycles and sportscars in EU, and 9003 in cars in the US. That’s just not true, many, many cars in Europe had H4 bulbs before LED and projection became popular, and still doesn’t explain the shorter base.
Serious, if they weren't meant to be interchangeable, one would have a notch or dent the other does not, or vice versa. That's basic engineering...
H4 is the fitting and the pin connection it is not the overall dimensions of the bulb. Both bulbs in the picture above are H4. If Ducati chose to use a particular bulb the fits within their headlight housing meaning that other brands won’t fit that is a Ducati issue not a bulb issue.
Hello! I thought I would revive this thread with how I am working on a backing plate design to accommodate longer back-end bulbs. I am thinking about making replaceable rear cups to be able to swap out depending on what bulbs people may be looking to run to still keep rain/water out.
Wood Red Rectangle Metal Plastic
Discussion Starter · #7 ·
Hello! I thought I would revive this thread with how I am working on a backing plate design to accommodate longer back-end bulbs. I am thinking about making replaceable rear cups to be able to swap out depending on what bulbs people may be looking to run to still keep rain/water out. View attachment 48187
Whoa ... that is very cool ... is the red prototype created by a 3D printer?
Hello!
yup! I’m an industrial designer and have a 3D printer at home for when we had a big project for work so I make all the things whenever I can! Like adapters for old wind hand guards until I order some metal spined ones.
1 - 8 of 8 Posts
