Same hereI'm 5'6" with a 30" inside leg. I can get both feet flat on the ground.
Try: Daytona Travelstar Lady GTX touring boots (have a 6cm higher footbed inside, not visible outside). If it is still too low get a lower-lot for the back for around 100 USD (just a piece between the suspension, take 30 minutes to mount it). If still too high try to lower down the seat. My wife is 1.56m and she has all 3 options - and is very happy now! All feet on the floor now, perfect handling, no limitations even in extreme curvy & bumpy alpine roads.My wife is 5’ 2” and rides a Scrambler just fine.
I think all the Daytona ladies specific boots have the 6cm heel wedge installed as standard. It is removable.Try: Daytona Travelstar Lady GTX touring boots (have a 6cm higher footbed inside, not visible outside).
Hi Kurt — Could you please explain (or post a link or photo) about what you mean by “a lower-lot for the back” ?Try: Daytona Travelstar Lady GTX touring boots (have a 6cm higher footbed inside, not visible outside). If it is still too low get a lower-lot for the back for around 100 USD (just a piece between the suspension, take 30 minutes to mount it). If still too high try to lower down the seat. My wife is 1.56m and she has all 3 options - and is very happy now! All feet on the floor now, perfect handling, no limitations even in extreme curvy & bumpy alpine roads.
Best Regards
Kurt
Hi YELLOWHEAD,
you can add a distance piece in the suspension which lowers down the bike by 25mm. This part is officially available and approved for the Ducati Scrambler. If you ever sell it later you can put it out again and the height is back to normal. As soon as I have time I will make a photo and post it here.
Best Regards
Kurt
Thank you, surfguy! Very interesting.Here is the distance piece (yellow galvanized on top of the spring of the suspension) I mentioned. Gets the Bike 20 - 25 mm lower. Approved by Ducati and accepted by the police (here in Europe and Switzerland). I am sorry but I don't know where my Ducati-dealer purchased it - but it is a standard part.
AND YES: you have to drop the fork also by 10mm to keep the bike geometry unchanged. No issue.
