1 - 20 of 26 Posts
· Premium Member
  • Fill up the tank to capacity with the proper mix of gas and STABIL. Run the bike until it smokes a bit - then top it off again.
  • Pull the spark plugs then drip a teaspoon of motor oil into each head, re-install plugs.
  • Remove the battery and hook it up to a trickle charger - modern batteries like the glassmat in the Scrambler do not require fluid addition
  • Put the bike on stands and let most of the air out of the tires
Then, when you want to take it our of storage...
  • Drain all fuel - replacing with fresh
  • Change oil and filter
  • Re-install battery
  • Start her up and let her idle
  • Refill tires and hit the road
· Premium Member
On my bikes equipped with FI, I actually never "winterize" (I ride in the cold - as long as there isn't any snow about).
Never had a problem with this "method" as it is basically impossible for decaying fuel to clog up modern injected systems.
· Premium Member
Or you can do what I do....
Nothing...
Its always on a battery tender whenever its in the garage.
Maybe every month or three I pull the cover off, start it - let it get up to temp - run it for 10 min more so fan cycles on and off and then switch off - leave to cool. recover.
Mine is Garaged - so never gets really cold.
I have tried fuel stabaliser - it made no difference - I fitted it to 2 bikes and did not to the other 2 - bith started and run correctly.
As for dumping oil and fuel - why do that??
Modern Synthetics do not get as Acidy as previous - even if they do - standing is no different to normal use.
As for fuel - if you choose fuel stabilisers - which is OK - then why drain off - they burn out with the fuel.
Keeping weight off the tyres is a good idea... but not essential... Do new car that are stored in lots get their tyres raised of the ground and fuel and oil dumped - hell no.
Near me the big import yard - near the sea (SALTY AIR) has maybe 20,000 cars - I am sure some of them must sit there in the open for a year before being sold..
There is nothing wrong with what Tony is saying (except maybe oil down plug - where you would need to crank engine by hand to distribute the oil - or it does no good - and just sits on the piston and does not coat the bore) - but is it needed??
4 bikes for maybe 6 years - never an issue with doing next to nothing... just my POV
1 - 20 of 26 Posts
