1 - 20 of 20 Posts
hi guys
I saw some time ago this picture with kinda wood side panels and I felt in love with it... anyway I think whey they come out they are going to be expensive.... I've seen some leather as well like this guy
Jem Reyes (@moto_banker) • Instagram photos and videos
anyway I was thinking getting some of this vinyl wrap and follow the guide to remove my side panels or sticker I still don't know and has some wood side panels
this vinyl wrap
Buy Products Online from China Wholesalers at Aliexpress.com
or anyone else has a better idea to fake this wood side panels?
thanks a lot
I tried wood veneer several different ways. No go. Because veneer cannot stretch, there are a few spots that will absolutely not work. The wood cracks before it would make the bend. If you are very good, you could cut and splice the veneer, but I didn't like it because you could see the cuts in the grain. I'll try and find a pic of my failed project to post.
Found it
Wood Wood stain Plywood Hardwood
Discussion Starter · #5 ·
Found it
scowa18 thanks a lot for sharing your experience I bought the one I link in my thread I hope it's not that thicker like the wood veneer you used
wish me luck
thanks
Discussion Starter · #11 ·
Discussion Starter · #12 ·
I ride my bike only on weekends.... and today I realize that side panels get pretty hot.... now I am doubting the vinyl is going to last or work at all since I am thinking it will make bubbles when the tank gets hot
so I think ichitz idea is the way to go
Some vinyl wrap will have a checkered patern on the adhesive side to aid in air pocket removal. It helps but is not necessary. Spray a mild soapy water concentrate on the surface before applying the wrap. This will allow you to reposition the vinyl if you make a mistake and also makes it easier to get air pockets out. Use a hair dryer to stretch the vinyl and form it around edges.
Discussion Starter · #20 · (Edited)
it scares me now
looks like a very professional work... not easy for beginners... I am going to practice then
I bought 2 vinyls just in case I screw up with the first one
1 - 20 of 20 Posts
