I'd love to hear what you make of the difference. i swapped my 2015 tube for a 2017 and I found the ride is so much more relaxed.Oh yeah I've already swapped my tube out for a throttle tamer. So I'm gonna swap OEM tubes with WCB45 and then I'll be able to compare the tamer with the 2017 OEM like you.
:3some:Learn to use your rear brake in this situation, and keep the throttle slightly open.
Helps a lot, on any bigger capacity bike, especially twins and single (because of the bigger engine braking).
This is supposed to bike control 101, which you use in slaloms and U turns all the time
