21 - 40 of 79 Posts
Yes, Bluetooth to virtual comport is working, it gets a connection to the dongle.
I got an answer from Lonelec saying that the ECU on the EUR5 (2021) isn't compatible with Melcodiagram. Might be a dead end, but I'm sure that I've read about people resetting their "newer" bikes...?
Ok, now it's validated that both the Bluescan 2 dongle and the cable is working.
First a test in my car with torque without the cable of course - works.
Then my Sled, dongle + cable - works with torque - can read the non existing fault codes, get a reading of RPM etc.
When starting Melco it only allows me to use the correct port (checked settings also).
It connects to the ECU but then freezes when "Setting up ELM", I have to "force close" it.
Tried both with "any bike" and "M3C..,."
Any ideas?
Any ideas?
Any update on situation? As I have eur5 and dont know what to do now 😬
Sorry but no, I haven't tried connecting them for two weeks now.
But everywhere I look it seems like the EUR5 with M4C controller is totally locked. I've also asked UpMap if there's any device/map for the EUR5 - but no...
I've started playing with the thought of changing the controller to a EUR4 controller from another market... But would that work...?
Rexxer has replied that the EVO unit should be compatible with EUR5 (M4C).
Haven't asked if there's any limitations in the functionality, I guess it might be.
But - I've reinstalled everything on my laptop and will give Melco another go this evening. According to the developer it shouldn't freeze as my version did.
It might be because of some windows updates that wasn't installed on my laptop. I'll report back when I've tried again
Good news, hope it will work 🤞🏻
After a fresh install of windows I finally got Melco to communicate via the ELM327 interface. Sadly it isn't able to "speak" to the M4C controller, this controller residues in the post 2021 EUR5 Scramblers, I don't know if Scramblers without EUR5 has the same controller... Cornering ABS - does that need the M4C!?
I'm still hopeful that this will work in the end when JP gets his hands on a M4C controller. Rexxer told me that the EVO is compatible with M4C, if that's true it should be able to both map and reset the service indicator.
Update - Thanks to JPs efforts and hard work we finally succeeded in resetting the Desert Sled 2021 EU5 service light. This bike is equipped with a Continental M4C ECU.
Melco will be updated for this bike from now on. If you guys use it, make sure to donate! JP is doing this on his free time and helps us save a ton of money!
The 2023 Ducati Scrambler Nightshift Next-Gen is not equipped with a pre-installed quick-shift system. However, you have the option to acquire it as an accessory. While the installation process is straightforward, the bike's ECU requires reprogramming before the quick-shift functionality is enabled. Could the JPDiag MelcoDiag be used to configure the quick-shift feature?
Discussion starter · #34 ·
I doubt it. Besides, that would be construed as theft of chargeable functionality from Ducati. Often if you reset an ECU on other bikes, you might lose the previously purchased software quick-shift option. Resetting the quick-shift option in the bike menu afterwards will return your previous purchase of a QS - I found this out on a Triumph 660.
Just use this JPDiag MelcoDiag functionality for what it was intended for by the author, JP - namely ECU fault code reading and service light resetting, and make sure you him a donation towards his coffee for all his hard work.
Reactions: Javerhammar
Update - Thanks to JPs efforts and hard work we finally succeeded in resetting the Desert Sled 2021 EU5 service light. This bike is equipped with a Continental M4C ECU. Melco will be updated for this bike from now on. If you guys use it, make sure to donate! JP is doing this on his free time and helps us save a ton of money!
Hi Ive been reading your conversation with JP 🙂 damn its confusing 😂and i thought im not bad with computers... Got all the cables, gonna try not to mess something by trying 😅🤞 Any chance maybe you could write short step by step for those who have M4C?
I followed Ducati Passions guide and the steps is actually the same even though we have the M4C with one minor change.
Instead of choosing "M3C" you choose "Any Bike" at the top left corner.
The other issue I had was the Bluetooth interface and a computer that wasn't up to date. This issue was resolved by actually updating windows with the latest updates.
I'm on a trip for the upcoming week, but I believe I took some notes of which address we have to use to scan the M4C for fault codes.
When I get back home I'll take a look and share that information here.
Please feel free to ask if any questions :)
Quick question, I want to donate, should I do it before or after applying for license? (Actually I already filled the form for license) just wondering if I still can donate after he sends the license file 🤔
P.s. so far so good been able to connect and scan and it recognised the bike 😁
At last, I have reset my Service Indicator for another 7500 miles on my 2017 Scrambler Desert Sled using the FREE not for commercial use JPDiag MelcoDiag Desmo light reset software tool.
I was using a very old Win 7 laptop.
1. Buy the correct cable(s), search eBay for an "ELM 327 FTDI cable and 4 pin Ducati cable" and buy both cables as a package for around £33. It has to be ELM chipset, don't get anything else. (I thought I already had the correct FTDI-OBD2 cable - I didn't!)
2. Google "VCP drivers FTDI" and download the Virtual Com Port drivers file and install them on the PC before you plug in the USB FTDI ELM 327 cable you just bought. You also need ELM327 v1.5 software driver - it might come with the cable on a disk, otherwise download and install it on the PC
3. Using Windows Device Manager check or set your COM port listed to 38400 bps.
4. Download JPDiag MelcoDiag software from 5. Start MelcoDiag - set MelcoDiag button on the opening screen to M3C
6. Follow the instructions to get a FREE licence - a key file is sent to you as an email attachment within a couple of hours and you load the key into the MelcoDiag folder and restart MelcoDiag. The screen will tell you that an email has been sent to gift you a FREE license (it arrives as a lic.cle file which is pertinent to your VIN number and ECU code)
7. Copy the lic.cle file into the same folder as the MelcoDiag software.
8. Plug in the USB FTDI OBD2 cable to the PC, remove the scrambler seat, remove the plastic battery cover with the one 4mm Allen bolt. Then locate the 4 pin diagnostics plug under the plastic battery cover next to the USB port. It is a black cable with a connector on the end. lift the plastic tab on the connector to remove the plastic cap and plug the second Ducati cable into the OBD2 cable and into the now exposed Ducati 4 pin diagnostics plug on the bike.
9. Start MelcoDiag once you have the licence key (lic.cle) file loaded into the same file directory as the MelcoDiag folder
10. Turn on the bike ignition and then press Connect on the MelcoDiag Home tab. The lights on the connect button should go green on the MelcoDiag screen under the Connect button and all five lights on the cable should flash at some point.
11. If you get a error message saying ELM software not detected, you have bought the wrong cable - start again on eBay. (I should know, I did this first of all)
12. If everything is green on the screen under the Connect button, set MelcoDiag on the opening screen to M3C
13. Open the Reset Tab on MelcoDiag and click the Desmo service reset button once. Wait for the corresponding 'ding' sound (up to 5 seconds later) and then turn the bike ignition off.
14. Wait 15 seconds and turn on the bike ignition. Hey presto, the service indicator is now set to another 7500 miles. Yippeeee!
15. Make a donation to the JPDiag PayPal address to show your appreciation for all his hard work and for saving you a small fortune for not having to visit the Ducati dealer to reset the service mileage after a simple oil and filter change.
Many thanks to JP for building the capability and for saving me £300 ($400) for having to go to the dealer to reset the service light
Thank you for this very valuable contribution!
21 - 40 of 79 Posts
